ECAD-MCAD Replace board
ptc-174577
2-Guest
I have a PCB assembly in Pro-E, this was created with emn-emp files. The PCB guys have now re-spun the board so I want to replace this in the Pro-E assembly. When I drag the emp file into the pro-e assembly I am given an append option, but when I do this the board is not replaced with the new version. Can someone give me some guidance on this, I feel I am doing somthing wong here.
We have the same problem updating when the board has changed. Our work around is to open the old board part and delete everything out of the tree except the first construction step (the board outline). When you update with the new board, it will rebuild the keep-outs and mounting holes. This problem is supposed to be fixed in WF4...
