Edit dimension properties slow
ldewilde
When selecting dim properties it takes almost 5 seconds until the menu 'Dimension Properties' appears.
Even in a very simple drawing. This is very annoying.
Version 19.0 M040.
Same issue, it has been this way since at least 18.1.
Creo Element\Direct Modeling 20.6.0.0.0
