Example code to Save As (Save a Copy) an existing assembly using VB API
sndong-mefane
5-Regular Member
There is an example code using JLINK available here: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS153609&art_lang=en&posno=1&q=vb%20api%20assembly%20save%20as&…
But I am looking for the VB.net version. especially the VB.net version of the following portion:
in VB API, "model.Backup" does not seem to work correctly, and "model.copy/copyandretrieve" don't include the part files.
Model model = session.RetrieveModelWithOpts(modelDescriptor, pfcSession.RetrieveModelOptions_Create());
ModelDescriptor md = model.GetDescr();
is there an equivalent to "GetDescr()" in VB API?
Does "model.Backup(...)" works correctly in your VB.net code?
Stephane
For those who Need to do the same thing using VB.net, here is my solution:
Imports pfcls
Imports System
Module Module1
    Sub Main()
        Dim connection As IpfcAsyncConnection
        Dim cac As New CCpfcAsyncConnection
        Dim session As IpfcBaseSession
        Dim template As IpfcModel
        Dim path As String
        Dim descModel As IpfcModelDescriptor
        Dim opt As IpfcRetrieveModelOptions
        Dim Modi As IpfcModelDescriptor
        Dim win As IpfcWindow
        'Dim descModelCreate As CCpfcModelDescriptor
        path = "C:\ptc\Creo_2.0\Parametric\bin\parametric.exe"
        Try
            'Start a new Creo Session
            connection = cac.Start(path, ".")
            session = connection.Session()
            session.ChangeDirectory("C:\work4\model\")
            session.LoadConfigFile("M:\PRO_E\Creo\configs\config.pro")
            connection.EventProcess()
            session.AuthenticateBrowser("******", "*****")
            System.Threading.Thread.Sleep(5000)
            'Open and display the template assembly model located in M:\ drive
            opt = (New CCpfcRetrieveModelOptions).Create()
            opt.AskUserAboutReps = False
            descModel = (New CCpfcModelDescriptor).CreateFromFileName("axialcasing.asm")
            descModel.Path = "M:\PRO_E\Creo\start_files\templates\07_Exhaust_Casing_3D_models\Type1\"
            template = session.RetrieveModelWithOpts(descModel, opt)
            win = session.GetModelWindow(template)
            template.Display()
            Modi = template.Descr()
            Modi.Path = "C:\work4\model"
            template.Backup(Modi)
            connection.Disconnect(DBNull.Value)
        Catch ex As Exception
            MsgBox("problem")
        End Try
    End Sub
End Module
Imports pfcls
Imports System
Module Module1
    Sub Main()
        Dim path As String
        Try
            template.Display()
            MsgBox("problem")
        End Try
    End Sub
End Module
