Dear All
Please help me.
I have a problem with execute in assembly.
currently im working in creo parametric 2.0 M130.
When im going to make a assembly by using part models developed in Wildfire 5, i get this type of problems.for every parts in creo assembly.
but there are no problems,
create part in creo 2.0 and using that part creo assembly.
read following documents. Maybe their contents will help you.
MH
Thank you Martin,
i get this window message,
when, open first time assembly model file (wf5) in Creo 2.0 pro program
After that, problem with execute in assembly.
Thank you
I think this message is warning, only. Can you zip and upload your data ?
MH
