Hello
Could someone help me with flattening in Creo. The problem I face is , I have 5 shrinkwraps and when I try to flatten I am unable to pick the shrinkwrap points to flatten , so in the end I am able to see only the cable in the flattened model and not the shrinkwraps .
In your Harness Assembly (prior to flattening):
1) Make sure you have aligned the axis of your shrink-wrap to the network on all five shrink-wraps.
2) In the Ribbon tool bar, under components, pick "Attach to Harness". You will need to attach all five of your shrink-wraps, using this method.
3) Regenerate and save your assembly.
4) Bring up the flat model and regenerate. (they will show up)
Thanks Lori!!
If Lori's hint helped you solve your issue, please take the time to mark the post as Correct Answer.
This will help community to sort out threads that still need to be answered from those where information can be drawn from
Gunter
