Hidden lines failing in model and in drawing...help!
ssywak
I've created a perf-board (some might call it a bread-board), but when I try to incorporate it in my final drawing, what SHOULD be hidden lines are not hidden.  Visually, it is unusable.
When I go back to the model, it ALSO fails the "hidden lines" routine
It SHOULD look like this (shaded works fine):
But instead it looks like this ("No Hidden" fails):
I've checked the model tree.  There are no errors indicated.  I've regenerated it, without any errors popping up--except the obvious, visual one!  All lights are "green."
Any ideas?  I have bunches of objects assembled to it up the line; I REALLY don't want to have to recreate the perf-board.
thanks in advance.
StephenW
(To:ssywak)
Threaded holes? Right click on the view and "erase cosmetics".
Or right click properties and turn on hidden line removal for quilts under the view display tab
StephenW
(To:ssywak)
Dale_Rosema
(To:ssywak)
This discussion may be of some help to you?
Cosmetic threads? Hiding threads in hidden line removed view
Dale, that was exactly it!  Cosmetic threads!
I edited the initial hole, which was threaded, and UNCHECKED the box "Include thread surface" under "Shape."
And it all resolved.
Thank you everyone!
Dale_Rosema
(To:ssywak)
Don't forget to mark yours or my answer as correct for those who may search on this topic.
ssywak
(To:ssywak)
I must be missing something.
If I have the view set to "No Hidden", I get nothing when I right click the general view area.  If I right-click over a part, I do NOT get a choice to "Erase Cosmetics."
If I select the part, and right click, I don't get Properties, OR a choice to "Erase Cosmetics."
None of what you say makes sense to me.
This now becomes a little more important, as I'm finding OTHER parts with Cosmetic Threads allowed that are causing me the same problem.
I'm running Version 2.0.
StephenW
(To:ssywak)
My response was specifically drawing related. I think you are talking about the model.
On quick way is to turn on the fast hidden line removal option.
Another way is to add your feature to a layer and turn off the layer.
StephenW
(To:StephenW)
FYI, Fast HLR sometimes causes other issues along the way but I can't remember exactly what they were.
Correct.  I enabled Fast Hidden Lines Removal, but it seems to be (it claims to be) on a session-by-session basis, unless I mess with config files.
I haven't really played with layers, though...not yet.
And I'll try your original approach at the DWG level.
Thanks again.
