How do I insert multiple drawings onto one sheet?
jhorst
I am working in Creo Parametric 2.0 and am trying to consolidate several wiring drawings in Creo onto one sheet. I have one drawing that I'm starting with just as a test, but I can't figure out how to put an additional drawing onto that same sheet, and maybe snap that drawing in line with the initial drawing. Is there a way to do this?
Thanks!
mender
(To:jhorst)
I think you might be thinking more of drawing mode > layout tab > insert group > Overlay > Add Overlay > Place Sheet.
dnordin
(To:jhorst)
James,
You cannot directly add another drawing into the same sheet.  You can, however, merge drawings together, and then move the views/data from one sheet to another.
In Creo Parametric 3.0, drawing mode, Layout Tab, Insert Group, Import Drawing/Data.
Dan N.
mender
(To:jhorst)
jhorst
(To:jhorst)
I tried both what you and Daniel had suggested, but I was curious if there was another method I didn't know about that actually allowed you to put another drawing alongside the other one in the same sheet, but unfortunately you can't just do that.
Thanks!
