How to Repeat Region Left to Right
CG_1832600
Hello All,
Software Version: PTC Creo Parametric  9.0.3.0
We are trying to use the repeat region of a drawing table to input assembly data from left to right. However, the system default inputs this information from top to bottom.
Specifically, we have a cable assembly that is made up of a single cable and a terminal on both ends. I would like the repeat region to input the data horizontally rather than vertically.
We are using the repeat region symbols:
asm.name
asm.mbr.name
We have tried the asm.mbr.name:1 or :2 to see if the code will have the individual part for the respective column but this did not populate.
Is the below example possible, or will the system default always be a vertical entry and there is no possible way of changing it to horizontal?
Want to have Table Example:
Assembly PN          Cable PN         Terminal 1 PN          Terminal 2 PN
Assembly 1                Cable 1               Term. 1                      Term. 2
Assembly 2                Cable 2               Term. 3                      Term. 4
Creo Default Table Example:
Assembly 1                Cable 1
Assembly 1                Term. 1
Assembly 1                Term. 2
Assembly 2               Cable 2
Assembly 2                Term. 3
Assembly 2                Term. 4
Thank you
AJ_TROGLIO
(To:CG_1832600)
How is your table defined?  i.e. how many rows/columns and how does it expand?
Tony Troglio
Anthony James Design Group
