Hello everybody,
I wonder how I can define the width of the lines when I use:
File => Save Current View As => Save as 2D Vector File => PDF
I didn't find any recipe or pen table file I could use for this. Or is it simply not possible to Change something here in CV?
I used CV3.1 MCAD when trying this.
Thanks for your help in advance.
Best Regards,
Fred
Creo View is not my area of expertise, but maybe this article I found in the database is explaining the issue: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS227363
Thank you very much Gunter,
Looks like I missed out that one.
