How to check family table Instance & generic using modelcheck ?
Yes, you can use ModelCHECK to add parameter in family table instances (Not sure about interaction with Windchill).
1. Set Check parameter FT_STD_PARMS as E in check file.
2. Add ModelCHECK parameter [MODE]_FT_PARAMETER [Parameter_Name] in start file (e.g. PRT_FT_PARAMETER PART_NUMBER)
Results in my test case was as:
Generic part is test.prt (with parameter part_number) and family table was as:
After executing ModelCHECK, results were reporting error and added all parameters.
End result was as:
Haris,
Could you explain this in detail?
Hi
In family table , the instance name is different to generic & instance .
But ,the parameter part_number remains same for Generic & instance because the instance will derive the value of part_number ( tools - parameter) from generic.
It is showing conflict when we are uploading into windchill because the part_number same for two different object (Generic & Instance) .
We found the solution for above issue by adding part_number as a parameter column inside family table dialogue box & remove the value of Instance (blank) & keep generic value .
Have more than 200 family table parts like this & its difficult to open all the family table parts and adding part_number column .
what I am expecting is when I am running Model check from generic,It should show part_number column is not present in family table dialogue box whether to be added or not if it is added what is the value for generic & Instance .
It would be better , if there is any solution in model check ?
End result was as:
Thank you so much.
Its working...
But I have small concern that the value for instance (part_number) is automatically taking from generic.But I want to give different part number to generic & instance.
Is there any option in model check to highlight Instance & generic value when running mode ??
You cannot assign different values for parameter in instances using ModelCHECK. However there is another check parameter in ModelCHECK (FT_DEF_PARMS) which will report if the value for parameter in instances is * (asterisk). It will help you find such instances and manually you can add values.
