Hai,
I am working on an customization project in CREO. Currently i am facing an issue to how to create few coordinate system's using the default CSYS available in the assembly mode.
When i went through the VB.API document i found few API'S which can be used to create CSYS. But as i am new to this i am not able to pass values to this API'S
I am listing those API'S here if any body has used any of these please guide me in this.
IpfcCoordSysFeat.OffsetType
EpfcDTMCSYS_OFFSET_CARTESIAN
EpfcDTMCSYS_MOVE_TRAN_X, EpfcDTMCSYS_MOVE_TRAN_Y, and
EpfcDTMCSYS_MOVE_TRAN_Z or EpfcDTMCSYS_MOVE_ROT_X, EpfcDTMCSYS_MOVE_ROT_Y, and
EpfcDTMCSYS_MOVE_ROT_Z
With Regards
Aghil.m
Hi Aghil,
this is just enumeration type. What functions have you found? VB.API does not support to create a feature, therefore you are not able to create csys using VB API. You can create feature only by UDF
Tom
Hi Aghil,
Tom
Hi Tomas,
My requirement is i have an excel sheet with corresponding X,Y,Z values in it. i linked this excel with VB.NET & also i have assembled a part into a new assembly sheet using VB. now i need to create Coordinate System in this assembly file with the values in excel using VB.NET is this possible.
I have seen few programs in PTC Support to create Datum points.
