How to designate parameters automatically using Model check ?
hsuryaprakash
According to image value in ModelCHECK parameter is missing, add PDM as value for parameters. e.g. PRT_PARAMETER TRIANGLE NONE EQ PDM
10 REPLIES 10
You may try using <MODE>_PARAMETER <PARAM> <TYPE> <FUNCTION> PDM (e.g. PRT_PARAMETER DESCRIPTION NONE EQ PDM) in start file
Hi
I have tried the above method but unable to achieve the desire thing.
Kindly find the attached image
Haris,
Does the syntax help you to designate parameter?
Yes.Now I can able to designate
Thanks a lot...
Could you please mark the appropriate reply as correct answer?
Hello, I'm strugeling with modelcheck (Creo3.0M110)
I added  lines in the file to check like below:
PRT_PARAMETER NAME_1 NONE EQ PDM
PRT_PARAMETER NAME_2 NONE EQ PDM
PRT_PARAMETER DRAWING_REVISION STR EQ LIST_PRT_REV
PRT_PARAMETER PRODUCT_MODEL STR EQ LIST_PRODUCT_MODEL
PRT_PARAMETER ENGINEER STR
PRT_PARAMETER CHECKER STR
PRT_PARAMETER APPROVER STR
PRT_PARAMETER ORDERNUMBER STR
PRT_PARAMETER SERIALNUMBER STR
PRT_PARAMETER PUMPMODEL STR
PRT_PARAMETER DOCUMENT_TYPE STR
PRT_PARAMETER DOCUMENT_CLASS STR
PRT_PARAMETER DIN24250_NUMBER INTEGER
PRT_PARAMETER INFO STR
PRT_PARAMETER SPEC_NUMBER STR
PRT_PARAMETER RELEASE STR
PRT_PARAMETER POSITION_NUMBER STR
PRT_PARAMETER MASS REAL
PRT_PARAMETER VOLUME REAL
PRT_PARAMETER DENSITY REAL
PRT_PARAMETER ID_NUMBER STR
PRT_PARAMETER NOTES STR
PRT_PARAMETER NATIVE_DESCR STR
PRT_PARAMETER NUMBER_OF_STAGES INTEGER
PRT_PARAMETER DRAWING_UNITS STR
PRT_PARAMETER PRODUCT_SIZE STR
PRT_PARAMETER FLS_UNIT_SYSTEM STR
PRT_PARAMETER FLS_LANGUAGE STR
PRT_PARAMETER FLS_DESIGN_FILE STR
PRT_PARAMETER FLS_MIGRATION_SOURCE STR
PRT_PARAMETER FLS_REGULATORY_REQUIREMENTS STR
PRT_PARAMETER FLS_ALTERNATE_NUMBER STR
PRT_PARAMETER COMMODITY_CODE STR
PRT_PARAMETER FLS_DESCRIPTION NONE EQ PDM
PRT_PARAMETER OEM_SITE STR
PRT_PARAMETER DESIGN_CENTER STR
PRT_PARAMETER EXTENDED_DESCRIPTION STR
PRT_PARAMETER FLS_ALTERNATE_DESCRIPTION STR
PRT_PARAMETER ORIGINAL_EQUIP_MFG STR
All parameters are added except the ones with "NONE EQ PDM"
PTC ModelCHECK
PARAMCHECK
   Error updating parameter(s): 3
    FLS_DESCRIPTION
    NAME_1
    NAME_2
Tried "NONE EQ PDM", it worked well. May be some for information will clarify.
@Mahesh_Sharma I have added parameter i.e. LBH which should carry the value of OVERALL SIZE of model check refereeing Article CS29792. But parameter is not appearing in Part/Assy parameters. Kindly help me out.
Thanks in Advance.
@GS_9583712
It seems added correctly in start file. however it will be worth checking:
1. ADD_CHK_PARAM is set to Y in check file
2. After executing ModelCHECK, is it using correct set of config files? You can check that in ModelCHECK report.
