Hi, I am facing an issue here.
When I created a drawing (use the template from my company), a message always occured.
Formart properties(Drawing properties) of the template such as the below:
I just think there are some relations between the message and the options .
And if so, Can I delete the "aux_line_font" from the tree options?
Many thanks !
to remove aux_line_font 21 SOLID option you have to change aux_line_font 21 SOLID to aux_line_font 21 SOLIDFONT
MH
Thank you for your reply !
However, my Basic PTC.com Account have not sufficient privileges to access to the area of eSupport.
Could you deliver the article CS20718 converting pdf by e-mail ?
thank you very much !!!
Here is the resolution [art of document.
then, update
However, I can not change aux_line_font 21 SOLID to aux_line_font 26 SOLIDFONT,
just add aux_line_font 26 SOLIDFONT options.
I still didn't solve the issue..
Thank you very much all the time !
OK, try below steps.
1. Open drawing which is prompting specified warning, Change aux_line_font 26 solidfont.
2. Create new drawing and merge affected drawing using Insert > Copy From other Drawing.
Save new drawing and open and check the message. If it is clear you can make changes in new drawing and use that.
I can not change 'aux_line_font 26 solidfont' ,
MH
I was finally solved it .
Thank you very much for your help,
and also for Mahesh Sharma !
