My computer will draw parts but Creo runs extremely slow and keeps locking up between commands.
I am currently using Creo 2.0 but I had 3.0 and it was even worse with speed.
I am running everything on a Dell Latitude E6400 which worked fine when I ran Creo on Windows 7.
Thanks in advance for any help I get.
Stephan,
if Creo is your working tool making money for you, then simply go back to Windows 7.
Martin Hanak
This happens due to graphic problem. Make sure before using creo you graphic drivers as well as graphic card should be updated. Also use latest version of software that get compatible with win 10 easily. I hope this would resolve your issue but i advice you to check Dell Latitude E6400 Manual for app crashing or unresponsive results of applications.
