This is a mirror copy of the entire assembly.
There is no need to separately set the reference side for mirroring, just press Save a Mirror Assembly. What side do you mirror copy to?
Also, is there any way to manually set the mirror reference plane???
@Inho-_- wrote:
Thank you for your reply.
So, is it possible to change the base?
I am afraid that Mirror Assembly command does not enable user to select mirror plane.
Solution:
assembly is mirrored about XY plane of default ASM_DEF_CSYS coordinate system. See picture.
Solution:
