I imported an OBJ file into Creo. It seems too much tessellated, and the worst thing is that I cannot apply material appearances. When I try to do such thing, it selects the entire part!
Is there a way to solve such problem? I attached the file.
Smoothing facets is not possible in facet models as far as I know.
Assigning appearances to individual facet features in a single model is also not possible (as far as I know)
One thing you can do, however, is to import your obj file into a part, and then create a family table where each family table member represents a single appearance or physical object in the scene. You can then assembly each family table member into an assembly and assign the appearance within the assembly.
Since you can't assign appearances to individual facet features, then you are stuck assigning a single appearance to the model and all it's features. however you can get around this by assigning each object in an assembly a different appearance. So, once you create all the family table members and assemble each into an assembly, you can then assign a different appearance to each part.
I grouped the sets of components since there were over 100 features in there. that way I could add the group as a feature to the family table instead of picking every single grape etc, and then having to toggle on/off in the family table. if you needed more individual parts, you would have to make a separate instance for each separate appearance/moveable part.
I do realize this is probably not "aesthetically" what you are looking for, however it is actually a good question, and I think this is a pretty good work-around when you are importing an underlay/reference model and need to be able to show/hide different parts and/or have different parts be different appearances.
Thank you very much for answer, until now I wasn't able to do it. Thank you.
I think you going the wrong way. Those OBJ files probably came from Maya or Max. Keep in those tools. There you will have all the tessellation and decimation tools you would ever want. The render tools are much better there anyway. The only reason I can think you would want to bring in OBJ to Creo is so you can use the Reverse Engineering tools on them for an assembly or something.
Bart Brejcha
I would actually agree with you for the most part, except that the question brought up an important work-around for anyone having to bring in "artists" concepts and work over them. A single part file is not able to have the seperate OBJ entities colored differently. Which is why I create the part with a family table. that way I can make each part with an appropriate color. The OBJ shells can be used as stand-ins, or for reference.
The reverse engineering module is not for mere mortals. at over $10k it's kinda on the ridiculous side. But the technique above gives me most of what I would ever need.
😉 for rendering purposes - imported OBJ files aren't smoothed at all. So yeah, it's not the right call if you want actual rendering output.
