In Creo 10 Change Coordinate system while exporting in STP not possible (possible in Creo 7)
VD_10406408
Hello All,
In Creo 7 when saving as a STEP, I was able to select the coordinate system in the window shown in the attachment but in Creo 10 the button stays greyed.
Does anybody know why this is ?
Most likely because you are exporting annotations. Uncheck exporting annotations in the step options.
Hi @VD_10406408 ,
Perhaps you could share some additional details or an example model.  Does this happen for all of your models in Creo 10 or just a specific one?
I attempted to create a STEP export using all of the protocols, part, assembly, even a part and assembly without any coordinate system and I had access to this selector in every attempt.
Mike
Thank you, did the trick
Good find, @Chris3
This is documented in CS445647 and CS289898.
Mike
