Inconsistent assemblies when no ground
lsilva
I'm trying to make a ball bearing using the Pin assembly constraint
Sometimes I need the internal runner to spin, and other times the outer runner to spin, therefore, I cannot make one or another Default.
If I make it default, I get "You may not drag a model belonging to the ground body"
If I leave it Automatic, mechanica cries bricks when I try to put it on an assembly
(And I don't like the squares between the icon and the name of the part on the model tree)
It's not only the bearing.
Sometimes I make a whole arbor loose so I can make it a pin on a third assembly
There's got to be a way to overcome this
dgschaefer
21-Topaz II
(To:lsilva)
You need to have a fixed ground in your assembly, but that does not need to be a part. I have not tried this, but I would thing that you can create an assembly axis and use the pin connection on both components to the assembly axis and an assembly plane. Then both would be free to spin.
When placed in a higher level assembly, you would then fix either the inner or outer component to other parts in the assy as needed.
LinkedIn
Your logic is perfect, but Creo is cheat-resistant
If I fix (Fix constraint) the object on the datums (if that's what you suggested), creo assumes that the object is the ground.
If I Pin the object using the datums, the not-well-constrained square appears between the icon and the name of the part and subparts on the model tree.
I will test this assembly on the bigger assembly, but I really think we are back to squat.
lsilva
(To:lsilva)
I CAN make the inner race default. If I attach that race to an arbor (rigid constraints, not pin - just as expected in real life), and the arbor spins, the bearing will work normally: the inner will follow the arbor, and the outer will be fixed.
I CANNOT do the above in a reverse order: Put the bearing somewhere, attached by the outer racer (which is pin), and After, attach the arbor to the inner. No: The arbor must hold the bearing.
Still looking for a way to make everything Not default AND consistent.
vzak
(To:lsilva)
Can you try this ::
- assuming bearing is assembly itself, add default datums (3 planes) and create Axes
- constrain inner runner by Pin to assembly datums solely
- constrain outer runner by Pin to assembly datums solely (not referencing inner runner at all)
at this point, both rings should rotate independently.
Now when you add this bearing.asm to higher level assembly - be sure to only use bearing.asm datums (planes + axes) for placement. Hope this way both rings will continue rotate freely.
Pls let me know if this resolves the problem,
- Vlad
lsilva
(To:vzak)
Thanks for the answer, Vlad
Performed the changes, but results were not different. The warning message from my first post still appears.
(Before the change, apart from the inner race (which is the first piece), all parts were pinned to the inner racer, instead of the assembly datums)
The mechanisms involving this bearing work fine. But I'm having a hard time to make things like gears.
This problem can be seen on a bigger picture.
If you find interest on this subject, you might look at my other thread, which involves this bearing.
Unable to make a gear
Maybe resolving that problem might resolve this one.
