I have a 4 bar linkage w/ a torque applied at one connection point (defined elsewhere in the mechanism). I would like to know the max force reacted on another surface (or point) at the output of the linkage.
I'm able to use a Loadcell Reaction measure (via Force Balance Analysis). I'm unable to figure how to do this over time (or duing the stroke of the mechanism).
Anyone have some pointers. I feel like this has to be possible.
Dan
Hi Chris,
Thanks for responding. So, I have Radial Force Measures at each of the hinge points in the linkage.
However, I’m actually looking for the max force output achievable on a non-hinge surface. The sketch below is similar to what I’m looking for. It’s obviously quite simplified.
Thanks again,
Dan
