Printer Lineweight
ptc-4482052
1-Visitor
Printer Lineweight
Hello Planet PTC,
As a new user of Creo 1.0, I've run into an issue with the final printing that I have been unable to solve. Any member of my assembly that has been sectioned, the entire sectioned member and not just the cut face, and the border of all detail views are printing extreamly heavy. After searching for a long time, I have been unable to find any configuration setting to fix this. I've tried manually assigning a linestyle to the sectioned member, but this did not work.
Is there a setting that I'm missing somewhere that will correct this lineweight issue?
Hi Ted...
I'm not sure if the lineweights in Creo can still be manipulated with a table.pnt (pen table file) but here's one to try it with. Try pointing to this file in your printer setup and see if this corrects the problem. If so, I'll send you the entire guide I wrote on how to manipulate pen table files.
Thanks!
-Brian
