I am trying to find the torque through a reverted gear train. I am having trouble with the output torque.
1- I applied servo motor -> input motion axis-> -360 deg/sec
2- applied force motor-> input motion axis-> constant 100 Nmm
I achieved the velocity results there's not a problem. So, I want to measure output torque on the final gear as pics.
To calculate the input torque, I defined a servo motor together with a force motor in dynamic analysis. İf not, it calculated input torque "0", output torque_1 and final_gear_torque with abnormal results.
1- Do I have to define the servo motor for calculate the input and output torque.
2-It doesn't calculate the output torques anyway. Whatever I did I can't find this problem's source. Could you help me plese?
Jonathan is correct - you need to apply a servo motor to the input axis to drive the system at a constant speed, and apply a torque motor on the output axis (or visa-versa). The torque motor will provide the load the system will see throughout all components. Applying a servo and torque motor to the same axis is redundant and the servo motor will "win" by default.
Chris
I'm not an MDO user... but just thinking about it, perhaps you need some resistance to movement on the output in order to generate torque?
In a real situation, if there was nothing connected to the output then the speeds would work out as you show, but it's not possible to generate torque without an opposing load to react it.
Our gearbox test rigs here work in either "speed-torque" or "torque-speed" mode - in other words, you control either input speed and output torque, or input torque and output speed. The principle is the same.
Chris
yeah, it really works. Thank you friends ı seek this since last month thank you
Thanks a lot for this post ..///
Mani.
