Hi folks.
Question, is there any way to link and lock the parameter of a mirrored part.
Right now it copies the parameters, but it doesn't update if I change the part where the mirrored part was mirrored from .
As you can see in the image. All those parameters are from the original part and are being copied . But it let me edit it. I need those parameters to be locked and being updated if i change their original part.
Thanks in advance for the help.
Hello @vicor3
Behavior produced by the system is expected:
Alternatively, you may consider a different way to produce what you're expecting. For instance a new part, getting an inheritance feature from source, which is then mirrored. You can then drive visibility of bodies to keep only the desired one, and add a relation in the "mirrored part" to keep dependency from source.
=> I attach here for you a commented movie to show how this may be approached.
Serge
Hello @vicor3
Serge
Thank you for the explanation.
