Mold Design Problem, not able to create parting surface
ssharma-2
Hi All,
Is it possible to extract core cavity design for this fan model. I've tried to create parting surface but not yet successful.
Model is attached.
pls help!
Shashank
Dear Shashnk
Please attach file
I think you can follow to split cavity
Dropbox - hil-vt-08-005_blade.prt.3
Binh
Dear Shashnk
Please attach file
Binh
ssharma-2
(To:bnguyen-2)
Hi Binh Nguyen,
Thanks a lot for your help. it worked the way i wanted it to be. Extracted core cavity out of your suggested parting surface and the machined tool worked absolutly fine.
Shashank Sharma
ssharma-2
(To:bnguyen-2)
Hi Binh,
Hope you are doing well, and sorry to disturb you again.
I was following your suggested method to create parting surface for another similar kind of axial fan model having 3 blades. But i am now stuck after creating the boundary blend feature.
Request you to help me with the steps ahead, also below is the link to the model i am able to generate surfaces so far!
https://www.hightail.com/download/UlRRNHA1Y3kzS3EwYjhUQw
Shashank
Inoram
(To:ssharma-2)
It appears you are trying to create a parting line on the "top" of the fins, but the part was designed for a parting line on the "bottom" of the fins. And you can follow the transition line around the center piece.
