Non linear draft angle
rjethwa
Hi
I want to pull a piece that has a draft angle, but instead of having a linear draft, I want the draft to gradually increase in angle so it turns into a curved draft (i.e. so starts at a shallow angle but increases angle as it is pulled further). Is this possible?
The other way to do this sounds like if I pull the part without any draft, and then carve out the side faces with the curved tool; difficult to explain what I mean, but think of it as if you have a piece of wood and you profile all the sides of the wood using an electric router with a curved router bit. Make sense?
And is this possible?
Thanks..
a exemple picture should be helpful.
Do you know the loft funktion ?
Have lock at the help.
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct /Drafting, /Modeling and /Modeling Express 8.0 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
