We have thousands of migrated assemblies. If you notice how Creo opens an Inventor assembly then saves it as a .asm, all the components are coincident to s Csys and the Csys has a dimensional offset to the origin. Is there a quick method to delete all constraints in an assembly? Or, is someone aware of a vendor that has created a add on for this function, or, it there a vendor that can create this?
Trailmaker 0.3 (the file is attached to the post at the end of the page)
This might work.
