Object has failed feature error
SS_10739479
2-Guest
While saving the assembly I generally receive this error "Object has failed feature", which does not allow me to save the assembly unless I suppress the part. When I check in the part I see no error.
What could be the main issue and how to resolve it?
What is shown in the message log in the status bar when you get this error?
Without more data it is wide open as to the possible cause. If you generally get this error on all of your assemblies when saving them then that is certainly odd. As a first step, activate the object with the error in assembly mode and expand the model tree to see if there is a failed feature shown.
Have you used the regeneration manager or global reference viewer to attempt to determine the cause of the regeneration error?
