I have a repeat region that I have split into 2 parts, the first part has the column headers but the 2nd split part has no headers. Can anyone tell me how to add column headers to the 2nd part.
Thanks in advance
Jeff
David,
I have used this method to separate tables in the past. I am for some reason having trouble with the "set extend" step for some reason.
When I select the table, then click paginate, a message appears in the lower text manager saying "could not set extent" immediately. I click on the set extent button and click on a row and the message remains "could not set extend".
Any idea as to why this is all of a sudden an issue? I am on creo 4.0 and this has worked perfectly fine (on same drawing even).
Thanks for any help,
Taylor
Are you working with a non report table?
If it is a simple table that you created and typed values into, there is no repeat region. To split this type of table, copy and paste then delete the bottom rows of the first and the repeated rows in the second.
Kevin
To keep Pagination topics together....
We have done the paginate command on a 76 item BOM at item 50. It throws the smaller BOM onto sheet 2.
How do you get it to show both parts of the BOM on the same sheet?
In WF4, we would cut and paste, but that doesn't work in Creo2m100.
Any and all suggestions appreciated.
