Request the ability to pass parameter values to the Operation Comments section for display in the NCL / Post processor file.
Hello Kevin
I am not sure you can directly pass a parameter thru the operation comment.
When I need this, I just create an auxiliary step at the beginning of the operation and just write a CL command in the customize window:
PPRINT/&NAME
This will output in the ncl file the content of the parameter NAME after the PPRINT
You can also output a function paranetre using.
PPRINT/&NAME:FID_STEP_COMMENT where STEP_COMMENT is the name of the function in your manufacturing asm
I hope this helps you
Olivier
Hi Kevin
I am doing a simular thing by using Parametes in comments to generated program headers, I am using Creo 1.0 at the moment.
I have found that you can't use Parameters in the operation coments dialog box to create header infomation, as Oliver has point out, come on PTC, lets fix this.
Instead I have created a comments machining sequence to act as a work around at the top of the machining sequences.
In that Sequence I have created a dummy tool number, set my spindle speed to zero and inserted a CL COMMAND with the following
which has the following
PPRINT/OPERATION: &OPERATION
PPRINT/&OPERATION_COMMENT_1
PPRINT/WHEEL: &JDE_PRODUCT_CODE
PPRINT/DRAWING NO: &DRAWING_CODE_NUMBER
PPRINT/CNC INDEX PROGRAM NO: &PROGRAM_CNC_INDEX_NUMBER
PPRINT/
PPRINT/&CADD_SYSTEM_VERSION
PPRINT/&MODEL_VERSION
PPRINT/
PPRINT/ PROGRAM IS MM/REV FEEDRATE
PPRINT/THIS PROGRAM IS USING SPEED RANGE: &SPEED_RANGE_CODE
PPRINT/&SPEED_RANGE_FEEDRATE_TEXT
PPRINT/FINISH FEED RATES PROGRAMMED AT 100%
PPRINT/
Within my post file, I am using ICAM for posting, I have created a macro to terminate the output of the tool call if it is the dummy tool, and with the spindle set to Zero, you don't get a spindle command outputed to the CL file, good to see this fixed from WF5.
With no tool call and no speed outputed, the comment appear at the top of the NC code file as a header.
Bit of a work around to automate the generation of program headers, but PTC needs to address the issue of using Parameters in the operation comments
Peter
Hello PTC,
we have the same request:
use Parameters in the operation comments dialog box to create header infomation.
Could you please fix this issue?
There is no functionality to be fixed. Use of parameters in operation is simply not implemented - see article CS178222
(The difference basically is like whether you cannot open the backdoor of your car because it is defective (and needs fixing) or because there is no door at all (not implemented for this model). In the first case you can expect a timely fix, in the second you can only hope a later version of the model has the desired door.)
Your best choice to request a functionality which is not in the software (or request a change in existing functionality) is by Product Idea
Hint: If you open an idea for this, post the link in this thread to generate more traffic of interested users to the idea, in order to promote it.
There is never a guarantee a product idea will be implemented, but the more votes, the more likely it gets considered.
Good morning, does anyone know if there is any news about this topic?
In particular, I would need that Creo automatically writes the settings of the clamping within the comments of the operation.
Thank you
Paolo
