Pipe feature OD in a Family Table?
mdebower
18-Opal
Hey,
I have a model with a pipe feature that I would like to add the OD as a variable in the Family Table.   I can edit the OD on screen when I pick it, and I know the dimension name: d12
How can I get that dimension into my Family Table?
-marc
use Other option. It enables you to enter dimension name.
MH
Marc,
You may try adding a relation as d12=OD and add that OD parameter in family table.
MH
ah HA!   I knew there had to be a relatively simple way of doing this, thank you Martin.
-marc
