Plotting with Wildfire 4.0 in windows 7
ptc-4383393
Is it me or does anyone else get a problem when using wildfire 4.0 on a win7 machine where the plot's come out with no words or text, but the boarder, and assembly print flawlessly? And is there a solution?
I've tried every setting possible (probably not every combination) and no results whatsoever.
I have a work-around but it provides unacceptable quality prints. (save as a tiff or pdf and then print, that works OK but the text is non-uniform and if it gets converted to pdf format text displays wrong and does not adhere to the code we use.)
John,
if you are able to print from ProE WF4 on Windows XP, then you must be able to print from ProE WF4 on Windows 7. How do you print a drawing ?
Martin Hanak
Martin Hanák
