Hi!
I found a thread from 2013 on how to post a bug, but it seems that thread is no longer valid. Technical Support is no longer available as an option.
I want to report some bugs about Creo Manufacturing so that the Devs can work on solutions.
Hi Scott,
Could you add the link for the thread you mentioned?
Also, if you have a SCN (Service Contract Number), you can open case with TS from the Case Logger. Then the TS engineer can check if the issue is actually a bug and file a SPR (Software Performance Report) for R&D to evaluate.
Amit
Hi Scott,
Amit
