hi,
we are using PTC JT interface to export Pro/E data to JT file format.
my proe part contain copy geometry feature which is hidden in layer tree.
when i export part to jt file the copy geometry feature hidden in Proe is appearing in JT.
can any one please let me know is there any method to resolve the above issue.
Manoj Waghmode.
I haven't tried this, as I've not got the JT interface installed, but you could try setting the Representation of those features to "Exclude". Just right click in the model tree on the features that you don't want, and pick "Set Representation to"
