Publishing PVZ Files with Combined Sates
doneill
I'd like to make good use of CreoView using PVZ & EDZ files but I must be missing some setup information.
When I first open a pvz in CreoView all the geometry is turned off.  I have to select a checkbox in the model tree to view it.  I'd like the model to be visible by default.  Is there a setting for that?
Also... I'd like to be able to use "Combined States" in order to establish defined views.
I discovered that there is a "Recipe File" (export_pvs.rcp) that requires "adapter/outputAuthorState=" be set to 1, otherwise it does not show Combined States at all.
But when I do that the geometry is not visible.  The Tree is populated but I can not view any of the parts...
What am I missing?
Mahesh_Sharma
22-Sapphire I
(To:doneill)
Check for filters in Creo View.. and turn on the Model Geometry filters..
Mahesh_Sharma
22-Sapphire I
(To:doneill)
@doneill
To Auto load the Creo view data, There is an enhancement, Set "Autoload All files" for Loading under File Options > General > Loading
For Combined states, Output Author stets needs to be Checked (set 1 when in txt editor. )
doneill
(To:Mahesh_Sharma)
Thanks... that's helpful!
One more issue though... I don't know why but my PVZ no longer shows any geometry!  The annotation is visible and the parts show up in the tree but model space has no geometry.
Mahesh_Sharma
22-Sapphire I
(To:doneill)
doneill
(To:Mahesh_Sharma)
Excellent!
Thank you so much!!!
