Reference cannot be used due to the scope setting of SKELETON for Environment
ptc-1813710
Hi!
I'm using 'Component / Component Operation / Cutout' in order to 'carve' the shape of a part into a volume (for CFD simulation purposes). I am getting however this message when getting to selecting the cutting model: 'Reference cannot be used due to the scope setting of SKELETON for Environment'. Any ideas how to get rid of this?
Thanks.
Catalin
Solution steps:
1) Go to File > Option >Configuration Editor
2) Select > Add.. Tab
3) Option name : default_ext_ref_scope
4) Option Value : all*
5) Click : Ok
Or, alternatively:
And then save it to your config.pro when prompted.
