In order to verify the instances of the family table, it is required that the generic have been regenerated (or already have the green dot). Then once the instances in the family table are verified and the family table has been closed the yellow dot shows (seeming like the generic needs to be regenerated again) even though all of the instances within the family table were successfully verified.
Any thoughts on this issue? Are others seeing this?
Thanks, Dale
Another part - regenerate the generic. Run verify instances - 1st one failed, the rest successful.
Went to retry the first one, and I got the error message that family cannot be verified is the generic is not regenerated.
Exited the table. Regenerated the generic. Got back into the table. First part was successfully verified
Exited the table, and the generic has the yellow dot, does it need to be regenerated again before I save?
