I have an assembly with two components. Every components has a simplified rep with the same name; UDSR where one feature is excluded. When I create a simplified rep in my assembly, I can select the User Defined Simplified Rep, pick UDSR, from each component. Works perfect. Now I want to create a rule-based simrep, where every component is loaded with the user defined simrep "udsr" in it.
In the rule editor, I am on the Status Tab, selecting Display. Is it possible to search for a user defined simrep with a particular name?
Hi All, I further deepdived into the knowledgebase showed me this:
Article - CS384183 - To create a Simplified Representation by Rule that will evaluate all parts tha…
Many thanks for your reaction. Topic can be closed.
Ruben
When you go into the rule editor, User Defined is not one of the options. I am not sure what option you picked but I don't think this is possible.
Rule Editor:
Manual Definition:
Ruben
Hello @Rubio74,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
