Saved and uploaded my work, why does then Creo ask whether I want to save my model?
psobejko
Does anyone else have this happen to them?
I save and upload my model before getting ready to end my workday, then I go ahead and quit Creo; at this point it asks me whether I want to save the very same object I just saved and uploaded.   What gives???  Can anyone explain it?
There is a config.pro setting prompt_on_exit. If it is set to yes, you will get asked when exiting a session.
Yes, I had the setting prompt_on_exit set to yes.
OK, I have dug a bit deeper into it: there is another config.pro setting: save_objects
By default, its setting is changed_and_specified - in which case, I was being prompted to save the object in my active window whether or not it had actually changed.
I changed save_objects to changed and now it acts more logically and only prompts me to save if the active object has actually been changed.
