Schematics 2 - will update to Schematics 4 when we go to Windchill 11
Occasionally I get the message:
What causes this? Is it a symptom of a problem?
Bill
Hi Bill,
This normally means that an item in your internal catalog for a design has the same sys_id as an item in the central catalog.
If both items are identical, this isn't a problem and I normally just synchronize.
This could cause issues however, if the item in the internal catalog is different from the item in the central catalog.
I think you can compare them, possibly by selecting "Details..."
Neil
