Hi everyone,
Here David, new user of PTC Creo Simulate.
Hope you can help me with this question.
As far as I´ve read about screw connection, there are different possibilities to simulate a screw connection.
As you can see in the file Pic.jpg, my assembly is a round plate, supported in the inner face of a round structure. There is a screw connection along the contact surface between plate and structure.
At the begginig I wanted to be the most accurate possible. So I created with the Intelligent Fastener Tool all the screws (10.9. M24x100). Once I had them. What should I do? I started to create "interfaces" (Simulate>Refine Model>Connections) between each screw and plate, and also each screw and structure. Also structure and plate interface. I wasn´t sure about it, there were a lot of connections. In my experience with Marc Mentat in University, you can select easily all the contacts with a contact table.
Anyway I did that. I wasn´t sure so I choose other option: create fastener in Simulate>Refine model>Connections>Fastener
Once I've done it, what should I do? Create also interfaces between each screw with structure and plate?
Also, Interface between plate and structure should be created??
Thanks a lot in advanced, as you can see, I have a "interface" doubt, don´t know
Can't help with the details of how to approach the fasteners; but your part appears from the sketch to have cyclic symmetry. If your load also has cyclic symmetry, then for analysis purposes I would cut away all but a single 'pie slice' of the model, and just analyse one sector with one fastener. This will slash your run times and/or allow you to use a much better mesh / more detailed model. It will also mean you only have to create interfaces and other features for one fastener instead of all of them!
Thanks for the answer.
My draw was without details, but not, it´s not symetrical, it has kind of windows, and a hole where an input shaft comes in.
My question anyway:
Should I create always Interfaces?
Because If I don't, the simulation would think that both parts are one (like one piece),
am I right?
You can simulate all sorts of things, but the first question is: what are you trying to accomplish? Without going into FEA terms that is. For example: "I want to check if the pretension in the bolt is sufficient for this application", or "I want to check if the bolt does not strip the threads from the cast iron part".
I want to see If how much is the allowable stress, to calculate with that my safety factor.
Should I always create interface between two parts in Simulate (because they are different .prt in the same assembly)?
Hello Paul,
Thanks for this nice example.
For those that might be interested, I found a document a little
similar to the WF 4.0 but in German.
Kind regards.
Denis
Hello Paul,
Bravo it is beautiful.
I had not made the rapprochement between the names. Sorry.
I have the first version 2009 WF4.
Well, it seemed to me that the model was similar to the book.
I have other books of SDC Publications on the subject.
You edit a Creo 3.0 Simulate version?
If this is the case, from what seems to be I the command.
Since the inception of RASNA, it is difficult to find books
Advanced ProMechanica simulation.
Kind regards.
Denis
Hello Denis,
my (last) "Pro/MECHANICA" is Creo Simulate 2.0 M080.
I will write no more book of Pro/MECHANICA.
Paul
Hello Paul,
You say that your latest work extends to Creo Simulate 2.0 M080.
but the indication on the book is:
Pro/ENGINEER Wildfire® 4.0 für und Creo Elements/Pro 5.0 (Wildfire® 5.0).
It is the latest version of 2012.
Kind regards.
Denis
Sorry,
not my book, I use Creo Simulate 2.0 M080.
Paul
No worry.
Thanks for the information
Kind regards.
Denis
Thanks!
How you made to apply the preload in that part of the screw?
I mean, I see with a volume region, but why those measures?
bolt preload:
Paul
Hello Paul,
I would like to take to ask some information.
It is interesting to see how you did.
For the restriction you could use:
define a cyclic symmetry restriction?
Is there a downside to using it?
The point that you have forced to the center of the tank, see the attached image, is to stress the whole?
Otherwise would it have been possible to use the inertial balance loading, which removes the possibility of Non-linear.?
Kind regards.
Denis
Hello Denis,
cyclic symmetrie ist for rotation, simulate help:
Y-fixed point is for static analysis significant.
contact is non-linear, always
Paul
Hello Paul,
Thank you for these valuable explanations and demonstrations.
Kind regards.
Denis
Good day David - welcome to PTC Community and I am glad to see you were able to find an answer to your question.
Best,
Toby
