Search for ECAD_REF_DES
ptc-2860737
Hi all
I'm trying to use the Search Tool to find an ECAD component by the
ECAD_REF_DES parameter, but I can't figure it out. There are other ECAD
parameters I can search on but not ECAD_REF_DES (Search Tool doesn't seem
to know it exists). Anyone know if this is possible and how to set up the
Search Tool to do it?
Also, and I just thought of this but haven't tried it yet, would it be
possible to use ECAD_REF_DES in a table repeat region (to show a BOM with
reference designators included)?
WF4
Doug Barton
Mechanical Designer
Parker Hannifin Canada
Electronic Controls Division
1305 Clarence Avenue
Winnipeg, MB R3T 1T4 Canada
direct 204 453 3339 x7309
fax 204 452 7156
www.parker.com/ecd
"PLEASE NOTE: The preceding information may be confidential or
privileged. It only should be used or disseminated for the purpose
of conducting business with Parker. If you are not an intended
recipient, please notify the sender by replying to this message and
then delete the information from your system. Thank you for your
cooperation."
jstone
(To:ptc-2860737)
Doug,
Try search by component with rule set to name.
jef
In Reply to Doug Barton:
Hi all
WF4
Doug Barton
Mechanical Designer
fax 204 452 7156
www.parker.com/ecd
cooperation."
Geez... that was simple. Although not obvious. Didn't think to try that
because it sounds like it should be looking for the model name (which
works also).
Thanks much
Doug Barton
Mechanical Designer
fax 204 452 7156
www.parker.com/ecd
That works nicely.you can also add a tree column ECAD_REF_DES.makes it easy
to find everything on a PCB.
Yes, I knew about the tree column for ECAD_REF_DES but if you've got
hundreds or thousands of parts it's a long list to search through by eye.
Doug Barton
Mechanical Designer
fax 204 452 7156
www.parker.com/ecd
Got the report region working with &asm.mbr.comp.name (took a hint from
the search tool answer). Makes for a very tall table however because each
component is now unique.
Doug Barton
Mechanical Designer
fax 204 452 7156
www.parker.com/ecd
Also you can't fix indices or dash items with the names displayed...
Eric Slotty
-<">mailto:->
414-362-2552
