Stepfile to Prt
sramanujam
Stepfile to Prt
I have a connector which is a Stp file and I need to use this in my assembly.
I have imported the Stp file and placed as per my Standard cordinates of my assembly .I am unable to pack(Schrumpfverpackung in deutsch) this Step file .
Is there any which way I can convert this step file to a prt file ?
9 REPLIES 9
when you bring in a step file, it is converted to a part file.
The part file may just be a closed volume solid but still a part file.
Why the file will not shrink wrap (Schrumpfverpackung = shrink package auf deutch,  but in PTC terms, I believe this is shrink wrap) I don't know.
I would guess that you have holes in your closed volume solid.
I usually do not have issues with these as my converted step files are contained within a larger assembly.
At this point, I will yield to others that may have more experience in this matter
I guess you want to create shrinkwrap and the connector is surface model. You have to repair it to get solid model.
MH
how do I repair the 3D Step Model ?
when I try to shrinkwrap the model , i see a message : No Geomentry selected.
I have attached the screenshots , may be it would help in understanding my problem .
model repair procedure is individual. please upload STEP file. Use How to attach file when you Reply to a discussion. procedure.
MH
Hi ,
this is the step file .
played around with the settings, this is the preview during the shrink wrap creation
no modifications to the part, just straight to shrink wrap
Ron
Thanks Ron it worked
If the information from a post has helped you solve your question/issue, please consider going back into the discussion and mark the helping post as "Correct Answer"
This will signal to the community that the thread has been answered (users sometimes go in to help and sometimes to find answers - this helps them finding the appropriate threads)
If it really worked then mark it as answered please. I was reading your query to help to only find out at the end that it was resolved. you could easily save other peoples time.
regards,
Sadik
