Summary - Column headings in repeat region tables
jonesc
Thanks to Anthony for the prompt answer
Add the column Feat Name to your model tree. Now select in the Feat Name column next to your component and add the name you require.
[cid:image003.png@01CFE203.D1398220]
0 REPLIES 0
