TEXTURE TRANSPARENCY
MB_10508968
Hi, how can I model texture for represent a metallic network?
Best regards.
Michele Barile
BG_9869104
(To:MB_10508968)
Hmm, You can set the model to a transparent appearance. Then set a surface/s to have a decal on them. If the decal has transparent background you can see through anywhere on the surface not covered by the decal. So if you can make a or find a mesh image with no background and apply to the surface you can see through it. This Arch Linux icon was the first no background image result I could find. I set the blocks transparency to 90% so you could see it was there and the back wall to a color to be able to tell you are seeing through the object to the back side.
Hi MB_10508968,
Thank you for your question.
I encourage you to bring more details and context to your initial inquiery.
For example, screenshots are useful to better understand what you are trying to do and will also increase your chance to receive meaningful help from other Community members.
Andra
I'm guessing what you're after is a texture that is partially transparent, like a wire mesh. Having it transparent in between the wires, while the wires still being seen? Unfortunately, I don't think this is possible in Creo today. You can have textures, and you can have transparency, but I don't think the textures can have some parts transparent and others not.
BG_9869104
(To:MB_10508968)
