Two Values in Model Edit
jeinberger
1-Visitor
Hello:
Creo 2.0.....I select a feature on a model, right-click and select the Edit option. I get two dimensions, which actually frame the current value I am trying to change. Example; a 35.00 dimension displays as 35.01 and 34.99 below it. And when I change one/both, the feature does not update.
This feels like a setting, but as an intermittent user, these are the things that trip me up.
Joe
My guess is that you have a drawing assigned to this part.
change the value in the drawing then regen
BenLoosli
(To:jeinberger)
You need to click on the dimension properties and set the dimension display back to nominal from limits. Then you can change the value. I get frustrated by this a lot on older designs.
Thanks Ben. That did the trick.
And this is an old training part.
Joe
Dale_Rosema
(To:jeinberger)
If you upgraded from an older version of Croe/WF, the dimensions were defaulted to Limits. You need to go in and change them to Nominal.
Thanks, Dale
Thanks Dale, I'll look into that.
Joe
Dale_Rosema
(To:jeinberger)
You're welcome.
Wasn't there some sort of configuration option (special hidden just for this) that would change all dimensions to nominal when opening old files.
I have a lot of old Pro|Engineer files that open like this too.  A real pain to fix every dimension manually.
Dale_Rosema
(To:TomD.inPDX)
It's seems like you & I have talked about this before:
Tolerance mode: Nominal vs Limits
From what you posted it look like in Creo 2.0
(still on WF5.0/Creo)
