I have a large assembly and would like to create a clear, step-by-step single animation. I am planning to use different simplified representations to generate clean exploded views for each stage of the animation.
However, in the Animation window, I can only see options to control explode states, timing, and view orientation. I do not see any option to control or switch simplified representations.
Could you please let me know if there is a way to operate or include simplified representations within the animation sequence?
I would appreciate any guidance or suggestions.
Kind Regards,
Sunil Kotte
Once you have an animation created, use the style at time option to switch out the rep you need.
Alter style state within animation
