anyone can tell me how turn off the "welcome to Creo browser" when Creo 9 is turn on?
I can't find on the config setting
HI, i resolve it.
that impostation is saved in the creo_parametric:customization.ui file and it is saved on exit.
Since my system did not allow me to overwrite it because it was in a common folder for everyone, I had to make a local copy of creo, modify the file and then ask to another user to overwrite it in the common folder.
Thanks for the help.
Right there on the image.
That box in the lower left corner, check it and the welcome screen will no longer be displayed.
Hi, yes that I know thanks. But everyday my sistem erase everything and make a new one system. The only things it keep is config end costumization
There isn't a flag somewhere in config to click?
The system is resetting too many files as that button click is stored in one of the customization files.
Why are you resetting the full system every day?
I run a batch file for launching Creo and only overwrite a group-wide config.pro. I leave the other files alone so the users can do their own thing, if they want to.
hi,
because where i work everybody need to have the same configuration so you can change local but the day after you have the same of everybody
thanks
I find the browser to be annoying. I suppose it's useful for maybe people with WIndchill(?) but I don't need a browser in my CAD software, I already have a browser, thank you very much.
I have the following settings in my config.pro to stop these shenanigans:
enable_3dmodelspace_browser_tab no
enable_partcommunity_tab no
enable_resource_browser_tab no
web_browser_homepage about:blank
Perhaps these will help you, too.
I also have config:
enable_punditas_browser_tab no
I am adding the punditas one in immediately. I thought I was stuck with that always coming. Gotta be more thorough when I'm scanning the config options, I guess.
I wil try thanks I hope to resolve
NOT WORK
the 1°,2°,4° i have the same. The 3° can't find
UI modifications are saved in following file
%AppData%\PTC\ProENGINEER\Wild{re\.wf\.Settings\creo_parametric_customization.ui
Next day
I have already try to export creo_parametric_customization.ui after flag the icon
but nothing change
HI, i resolve it.
For me in Creo 9.0 and 12.0 works this:
