What Analysis do I use.
brianlynn
I rarely need to use analysis, but I have a cast part that I need to
verify all the edges have been rounded on, is there a tool for verifying
this. I have stumbled around in the analysis menu some but it is not
readily apparent to me.
Thank you,
Brian S. Lynn
Technical Coordinator, Product Engineering
Disregard the previous e-mail I found a solution. Since I was just
looking for open edges, I added a round to the end of the part and then
check All Convex Edges, checked to see what was highlighted and the turned
that off, and then checked the All Concave Edges and checked those edges,
once I verified everything that was highlighted I simply canceled the
command and no lingering effects.
Thanks to anyone who put some time in to writing something up on this,
Brian S. Lynn
