I am new for Creo flattening and drawing from the flatten, I have created harness routing and done flattening as well, but I am not able to create connector table and wire table, I tried with all possible parameters, I am able to create a BOM table with same procedure.
Someone can help me on this please.
Jagadhees.
Jagadhees
Creating repeat region tables from a flattened harness can be tricky. And it's hard to find the syntax of the repeat region information in the help documents. But if you have the fields set correctly and they still are not populating, you may need to change the active drawing model from the sub-assembly of your flattened harness instead of your top level flattened manufacturing assembly.
If you're having trouble with the table fields, I think some of that information can still be found under the old Pro/Diagram documentation that is on-line.
Cheers,
Frank.
