We're using Creo 10.0.6.0 and currently evaluating the ECAD-MCAD Collaboration (ECX) which allows using IDX files. On the ECAD side, we use Cadence. We ran into a snag because we have rigid flex assemblies that use multiple thicknesses, but Creo doesn't support that yet. Many references here:
We have workarounds to manage these files today using EMN/EMP transfers. I'm interested in learning if others have already found workarounds to manage multiple thicknesses with IDX files.
Joe
We weren't able to find any viable workaround. We won't be adopting this module until they add the needed functionality.
You are in the wrong forum.
PTC has two CAD systems: Creo+ and Creo Parametric and Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
To move your post, click on the three vertical dots on your initial post and click on "Notify Moderator".
