add pos_nr to the same part in an assembly
DennisRehmer
To all,
I am looking for a way to assign, in an assembly, the same pos_nr needed in GPLM / WindChill, for BOM structures, without needing to do it each time for the same component. In the images below, I would need to pick in the pos_nr column for each one, change to Integer, give the value and then designate them. I am looking for a way that I can easily add it to all of them at the same time. We are finding it time consuming to have to do each one individually.
Any help is appreciated.
Dennis J Rehmer
ABB
if you want to create pos_nr as a component parameter, then you're out of luck. Requested functionality is not available OOTB. You have to figure out a way to do it yourself ... or have a special Toolkit application developed that will have the given functionality.
Martin Hanák
Martin,
I was able to get what I needed to be able to assign the pos_nr at the component level, in an assembly, when there are multiple occurrences of them.
Dennis
ABB
Hi @DennisRehmer,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
Catalina,
I was able to get this solution figured out.
Dennis
Hello DennisRehmer,
Please feel free to detail what has helped you in a reply, in order to benefit other members who may experience the same issue. You may mark that reply as the Accepted Solution for your topic.
Best regards,
Catalina
PTC
